I am wondering if the controls within LaserFromSound VST are MIDI mappable from inside a host such as Ableton Live?
Controls MIDI Mappable?
yes, most are. click the little triangle between the yellow dot and the yellow wrench in live, then you’ll get the available parameters.
ps. note that you have to decide if you want to animate r/g/b or h/s/b, you cannot animate both at the same time
