OsciStudio Version: v0.6.0.38 & v0.7.0.4
Operating System: Mac os 10.14.6 & on another mac with the latest os
Hello everyone!
I’d really appreciate it if you could give me some advice if you know how to work with the processing of two images on the same layer.
I noticed that it’s possible to import multiple objects on the same layer by holding down the shift key. I’d really like to be able to apply different effects to these two images, typically rotation and offset.
I’m not sure if it’s possible, but maybe with the right live code, there could be a solution.
I always have trouble understanding what UIDs are for and how to use them.
Something that would be even better is if I could choose for the different layers to behave the same way as when importing multiple images on the same layer with the shift key held down, having a sort of blending mode between the layers like in Photoshop. But once again, I imagine that’s impossible.
All of this to realize an idea that seemed simple in theory with this software but complicated in practice.
Also, this is my first post on this forum, but I’ve been reading attentively for a while.
A Huge thanks to this community that has changed my life forever and for all its kindness,
you are the coolest! Cheers!
