Does it make a difference visually whether or not you use 44.1khz, or 96, or 192?
I tried making some recordings in 44.1 and 96, and I couldn’t tell the difference, then I saw somebody post that they used 192, and I was just wondering why? Do you get a more realistic “smooth” appearance if you do? Is there any benefit visually speaking? Or is it just for audio quality?
There’s a huge difference between the different sampling rates. The more vertices, sharp corners, or cuts you have in your image, the harder it will be to draw a clear image. To avoid these problems using the highest sampling rate possible is a good idea. Jerobeam has a good example of this and other issues here.
