Hi guys,
I want to create a lie detector HUD with a heartrate monitor. Any ideas other than drawing a bezier curve in blender and using the trace effect?
Hi guys,
sounds perfectly fine to me
if you’re comfortable with coding, then that would give you a few more options to change it in real time,
but i really think blender+trace is a good enough combination already.
you can add a “knee” plugin after the trace and play a bit with the params, this should allow you make one end of the curve a bit darker than the other end.
