Livecoding fails on M1 MacBook
OsciStudio Version: 7.0.4
Operating System: 26.6
Title: Livecoding fails on M1 MacBook: “fatal error: ‘cmath’ file not found” after Xcode setup
Hi everyone,
I’m trying to use Livecoding in OsciStudio on my M1 MacBook Pro, but every compile attempt fails with:
fatal error: 'cmath' file not found
#include <cmath>
1 error generated.
Please fix your build errors!
Before this, I also saw this message after a successful compilation:
Compilation ok, error while loading shared library :(
My setup
•	MacBook Pro with Apple M1 Pro
•	macOS version: [e.g. macOS 26.6 — output of  sw_vers ]
•	OsciStudio version: [e.g. A7.0.4]
•	Xcode is installed in  /Applications/Xcode.app
•	Apple clang version 21.0.0 (clang-2100.4.1.1)
•	Target:  arm64-apple-darwin25.6.0
•	Active developer directory:
/Applications/Xcode.app/Contents/Developer
SDK path:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk
What I checked
The C++ header does exist:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/cmath
I also checked the OsciStudio executable and bundled libraries. They are universal binaries and include both  x86_64  and  arm64 , so Rosetta does not seem to be the issue.
What I tried
•	Installed Xcode.
•	Ran  xcode-select --switch /Applications/Xcode.app/Contents/Developer .
•	Verified that  clang --version  works and points to the Xcode toolchain.
•	Verified with  xcrun --show-sdk-path  that the macOS SDK is available.
•	Started OsciStudio from Terminal with:
export SDKROOT="/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk"
open -a OsciStudio
The error still appears.
Question
Is this a known compatibility issue with newer macOS/Xcode versions? Does OsciStudio’s Livecoding compiler need the standalone Command Line Tools at  /Library/Developer/CommandLineTools , or is there a setting where I can point OsciStudio to the Xcode SDK/compiler?
Any help would be greatly appreciated!
