I’m very new to this, but have been researching for quite a while now. I’m wanting to play a music file through an mp3 player, but it’s much less clear and blurry opposed to directly from my laptop. Should I be running the mp3 player output connections through something prior to the oscilloscope instead of direct? An audio mixer perhaps? Any help would be greatly appreciated.
Looking for a solution
Malocchio
you might have more luck with this question here: https://www.reddit.com/r/oscilloscopemusic/
anyways, your setup seems fine, especially if the one end of the splitter goes into an amp/preamp, and the other into the oscilloscope.
i guess you have two things to take care of:
- playing from mp3 will show you the compression artifacts
- your dac may or may not be DC coupled. if it isn’t, then the image will always self-center
hope that helps
