Manually Mapping a Midi Note to a Button Control
I know I can manually designate CC midi control for a slider by right-clicking and selecting “Add Midi Mapping” then entering something like “3.50” to control the value with MIDI CC#50 on channel 3, but is there a way to designate a note instead of a CC number?
For example if I wanted to enable or disable the “Trace” effect in a specific channel; is there a way to use “Add Midi Mapping” and then entering something like “4.#200” so that the “Trace” effect toggles whenever note 200 is played on channel 4?
I’m asking about this technique because of how using “m” to enter MIDI mapping mode only seems to work for slider controls and not button controls.
