OsciStudio Version:a7
Operating System: win10
example
One object not spinning why? and how do i fix it
You’re probably spinning the cube with the “Obj rx” slider on the grid effect, which offsets the rotation of clones in the grid, but not the original shape. Use a rotate plugin above the grid plugin to spin the original cube as well as each clone of the cube.
