OsciStudio Version: A6
Operating System: Mojave 10.14.4
i’ve try as the user manual 5.1 Global Shortcuts for the Keys and without any response. When i try to save files using A5.5 version, it works with problem.
oh no… i’m guessing it’s a gatekeeper issue.
can you try to start oscistudio from the terminal?
you would do it like this:
if it doesn’t work, can you copy&paste me the output of oscistudio?
do you also have this problem? i just tested and it works on my 10.14 (that doesn’t mean too much though
hey!
it seems the problem can be solved with this:
Open System settings > Security & Privacy > Privacy > Automation
Find OsciStudio in this list and make sure the box is ticked
See also Unable to Save/Record
